WTB: 67/68 V8 3 on tree shifter and clutch parts
I'm looking for a complete clutch linkage and shift arms.
I need both shifter arms and attaching hardware (compression nuts, tranny shift fork actuators, etc). Must come off a 2wd 67/68 with small block in original V8 position and 3 on the tree shifter. The shift arms are different than the 69-72 style because the tranny is different in these years. The clutch linkage parts I need are the rod from pedal, Zbar, engine ballstud and bracket, and frame z-bar retaining bracket with nuts/bolts include. These parts can come from any 67-72 smallblock V8 3 speed or 4 speed 2wd truck. Doing a 67 with small block and OE 3speed column shift tranny. Thanks __________________ |
I have everything you need. I am currently in the process of converting my 68 3 speed to a 700r4. So I have the trans, bellhousing, column, linkage, z-bar, starter, clutch assembly, clutch linkage, and clutch pedal. Let me know what you need.
Bob |
