Need Cheap springs!
I need new front leaf's for my 88 V10 Suburban. 1400lbs 3 leaf. I have found $105 so far. Anybody see anything cheaper? Thanks, Bradley
Re: Need Cheap springs!
Have you looked around for a local spring shop?
I would think it would be much more expensive.
craigslist? around i here i see 4-6" lift springs and stocks for around $50
Sounds like you are after stock 1 ton springs for the front? I have a pair of stockers I removed from my K30 and replaced with 4" springs. PM if interested.
$105 "is" cheap. The ones already on your truck are the only ones cheaper :cool:
Too bad you werent closer....I have a set of front +2 inches I'd give ya.....out of my 90 Sub.....
