-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   67 help with p/s and frame? (https://67-72chevytrucks.com/vboard/showthread.php?t=544087)
Ricks1971 09-21-2012 11:12 PM
does anyone have pics on how to put the dimple in the frame for putting p/s on a 67? thanks Rick
oldspowered67C10 09-22-2012 06:01 AM
Re: 67 help with p/s and frame?
Heres how I did mine.http://67-72chevytrucks.com/vboard/s...d.php?t=282720
nds1968 09-22-2012 07:09 AM
Post 120 I have a pic http://67-72chevytrucks.com/vboard/s...=286089&page=5 I just heated with a torch and hit with a BFH. I had a power steering box to check fitment. It turned out ok, not happy with the hammer marks but you'll never see them when the box is installed.
Ricks1971 09-22-2012 11:29 AM
looks like I get the BFH out and fire up the torches!
thanks guys
nds1968 09-22-2012 03:45 PM
You'll have to trim the front core support mount so that the PS box will line up with the existing holes. I just used a cut off wheel on a grinder for that. Also the bumper bracket will need trimmed to clear the box.
Further more some frame don't have the dimples where the bolt holes are located. I believe you can use a spacer to make up that difference. Nate
