Help! Plz
Can I swap 87 disc brakes and rearend
To a 70 I'm not good at spelling I can read very good so go rite ahead let me know... if can or how here's some pics that's always good http://i1224.photobucket.com/albums/...BF4BA8C8FA.jpg http://i1224.photobucket.com/albums/...275D751148.jpg Posted via Mobile Device |
Re: Help! Plz
Yes you can if your rear end is a leaf spring set up. Wont work if it is coil springs
Re: Help! Plz
What about the front Thay both have p/b do I need to change any of that
Re: Help! Plz
Yep...the front x-members will swap as well....go ahead and use the booster and all...probably the easiest route is to unbolt and swap:D
Re: Help! Plz
Don't tell me you're going to rob parts off that nice blue truck just to get disc brakes.
Just buy some $219 dollar 63-70 conversion spindles and auto parts stor 1-1/4" rotors and calipers,... and add them too your white '70. Use a 71-72 M/C and prop valve and you are done. For the rear,... buy a set of Moser axles and 71-72 5-lug brake drums. The days of finding oem parts to do disc brake conversions are over. And a crossmember swap is completely unneccessary! |
Re: Help! Plz
Re: Help! Plz
Re: Help! Plz
Just my opinion,... but that's crazy.
You will have to buy rearend saddles for the trailing arm rearend. You will also have to buy a super track bar since the later rearend has no place to attach the track bar. I could understand if it was a beater parts truck,... but to destroy a perfectly good squarebody just to get the brakes? |
Re: Help! Plz
Re: Help! Plz
Not without spending a bunch of money, parts swapping, brake tube bending, and bleeding, etc. Not just a bunch of parts swapping. I assume your '70 has trailing arms, not leaf springs? The prop valves are in different locations, M/C are diffferent, etc. Plus,... who would want that squarebody with drum brakes? Sell the blue truck and buy a disc brake kit for your 70,... |
Re: Help! Plz
It's not about the money I was just mad at 87 lol
