Underbed Tank Fuel Lines
I have a "92 stepside bed on my "72 and am getting ready to install a under bed tank. There is a filler door in front of the left rear wheel in the fender. Is that to long to run filler hose to? If not, that would make things pretty simple instead of cutting holes in the bed or somewhere else.
Thanks |
Re: Underbed Tank Fuel Lines
i'd think that is too far to run t and would b nothing but a problem and if you got it run i'd think to fill it at the pump wood take u hours
Fill hose is cheap, go that route. Go talk to a diesel repair shop, I got a long section for my truck from one of these outfits. Apparently garbage trucks they worked on needed it..
Posted via Mobile Device |
