-   -   hi im new and looking for some help (https://67-72chevytrucks.com/vboard/showthread.php?t=547597)
1975 GMC C10 10-15-2012 12:38 PM
Hello all i'm new here and i just bought a 1975 GMC Custom Deluxe C10 1/2 ton with a 250 inline six with the three on the tree now the guy i got it from changed it to floor shifter and it now only get 1st gear and reverse now i want to know how do i get it back to the column shifter any help would be great thanks
ps yes i am going to restore the truck to original
71maligreen 10-15-2012 08:25 PM
Re: hi im new and looking for some help
sounds like a linkage is loose or came off the shifter???
to get it back on the column you will need the original linkages from the column to the trans, i would give you mine but mine was converted to the floor before i got it as well!!
71maligreen 10-15-2012 08:26 PM
got a picture of the shifter?? mine is kinda worn and may be interested in yours if its a hurst???
1975 GMC C10 10-15-2012 08:32 PM
no i dont have the truck home yet as im trying to figure out the linkage so i can drive it home
71maligreen 10-15-2012 08:48 PM
if i remember correctly one arm is for reverse and 1st and the other is for 2nd and third??
i can get a picture of my linkages tomorrow for you if that would help??
71maligreen 10-15-2012 08:50 PM
did you look to see if one was disconnected or hangin loose??
1975 GMC C10 10-15-2012 08:50 PM
ya then i can get my truck shifting right then i can worry about the column shifter later on thanks
