front shackles
I need to raise the front of my truck to level it out
Can i use longer shackles and it still be safe? how long can i make theme? |
Re: front shackles
no one knows?
Re: front shackles
i was told 2" is the most. i had them on my f250 but i didnt have A driveline hooked up so idk about if itll mess up your pininon angle
Re: front shackles
Read the tech notes at the bottom:
http://offroaddesign.com/catalog/hdshackles.htm These will work: http://offroaddesign.com/catalog/Zero%20Rates.htm Off by more than an inch and you probably need different front springs. |
Re: front shackles
Warrior products make shackles that give you an 1-1/2" of lift, so they are probably 3" longer than stock. Any more than that and it will screw up your caster for your frontend alignment.
