rocker/ cab corner ????'s
ok i am getting ready to replace both rocker and cab corner on both sides of the cab...........in removing the old rockers, i am assuming i have to replace the corners first then the rockers.........this is my first bit of body-metal work other than adding some sheet metal to the floor of my 82 jimmy.any help or suggestions would be greatly appreciated.......
thanx BBB:confused: |
For the cab corners, only use as much of the new patch that is needed to fix the rust. You don't need to use the entire patch!!
ttt
