-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   69 GMC 12 Bolt (https://67-72chevytrucks.com/vboard/showthread.php?t=552395)
jlah69 11-18-2012 09:52 AM
69 GMC 12 Bolt
I've got a 69 GMC C15 with a 12 bolt rearend what is the best option for making it posi? It is used mainly for cruising but I plan to take it to the drag strip occasionally. Thank you for your input.
crazy longhorn 11-18-2012 07:09 PM
Re: 69 GMC 12 Bolt
Eaton unit....you did not state the gear, but hear goes....2.73-3.42 (3 series carrier) . 3.73, & slower gears(4.10,4.56, ect), 4 series on the carrier. :chevy: crazyL
dznucks 11-18-2012 07:43 PM
Re: 69 GMC 12 Bolt
X2 on eaton. I put a trutrac in mine with 4.10's. you dont know its there until its smokey burnout time or when the roads are wet.
Captainfab 11-19-2012 12:57 AM
Re: 69 GMC 12 Bolt
X3 on the Eaton.......
jlah69 11-19-2012 08:49 AM
Re: 69 GMC 12 Bolt
Found a Detroit EZ locker for sale for $100 would that be a good option or should I buy a new Trutrac?
