1966 4x4 FRT / Rear Swap question
Looking for information on swapping 73 & later frt / rear & springs plus the mounting brackets from the 73 & newer frame.
I searched the site but must no be using the correct terms. I have a 64 - 66 frame. Thanks. |
Re: 1966 4x4 FRT / Rear Swap question
I replied on your other post. Check out the link to my build below, I did part of what you are planning.
Thanks I am just learning how to use this board.
I screwed up placement of the first post. |
Plenty of build threads with info that you are looking for , you will just have to take some time and read them.
Just haven't come across it yet. |
