-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   Parting 1968 1 ton dually longwheel base (https://67-72chevytrucks.com/vboard/showthread.php?t=55606)
lazygaurd 06-06-2003 02:18 AM
I just bought this 1 ton dually factory camper unit for the original (68) 396 turbo 400 set up. Truch has 100003 original miles on it. I want the p/s, fan shroud, mounts etc. The cab is as nice as you will find for original. A few quater size holes in the drivers rocker but that is about it. Interier is almost perfect, green door panels, dash pad, seat with checked pattern, no cracks on steering wheel, tinted glass (no back window though). Very nice GMC grill. Carpet kit. Pass fender has rust under battery but I think the drivers is good. Split rims have been replaced. Not sure if it is a posi yet but will confirm. E-mail with requests for info.
Darrell... Brookbanks2@shaw.ca
I also still have a tach to sell. V-8 with wiring harness- $180.00
1969 GMC 06-06-2003 03:33 AM
is the steering wheel green?
lazygaurd 06-06-2003 09:30 AM
wheel
Yes it is light or pale green!
Blue68 06-06-2003 01:12 PM
Looking for a good underdash harness, non-rusted and legible fuse box with no/minimul wire cutting. Dash has speedo, fuel, oil pressure, ammeter, and temp. Also interested in the underhood (front) harnesses as well if not hacked.
Are the GMC and Chevy underdash the same, or close enough?
