-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Rear leaf springs (https://67-72chevytrucks.com/vboard/showthread.php?t=556962)
KVB 12-19-2012 01:57 PM
Rear leaf springs
I was wondering about my rear leaf springs, is there way to test if they are still “good”. Can a spring shop tell me if they will be good for a 1000 lb or 2000 lb load.
Can they be taken apart, sandblasted, repainted and put back together?
Ken
lolife99 12-21-2012 01:02 PM
Re: Rear leaf springs
Anyone?
1LowToy 12-22-2012 11:44 AM
Yes they can be taken appart and checked out. It's pretty back yard stuff. I took three sets appart, matched them up, added a #2 and 3 springs. Rides a little too stiff and I plan on removing the extra #3 spring to soften up the ride. The problem with mine was that the springs were mush and the truck would lean to one side. I found the the arches were different from left to right. Look in some of my previous posts and you can find the spring pics.
My wife fed my computer a cup of coffee and it choked along with the pics:uhmk:
asolde 12-26-2012 09:47 PM
I just purchased a set of springs, shackles, and bolts from www.sdtrucksprings.com I was going to pull them, clean them, rearch them, rebush them, but I think it's less head ache just to replace them and prolly cheaper too.
1LowToy 12-27-2012 02:08 AM
3 Attachment(s)
Not a bad price for the springs, till ya think about the shipping weights. Any way here's some pic of the spring build I did. Extra spring set was $10 plus new center bolt from the hardware store and some knuckle skin.
This spring set will hold an A** load more than stock.
asolde 12-27-2012 05:30 PM
Wondering if you could post up some better pictures of how you have all your jack stands placed under the truck to support it.
skillet 12-29-2012 02:51 PM
When you say #2 and 3 springs, do you start counting from the bottom or the top? Thanks.
