-   -   cab question? (https://67-72chevytrucks.com/vboard/showthread.php?t=559473)
southern parts 01-06-2013 06:26 PM
cab question?
I found a 60-61 c -70 with a pristine body. i know the fenders are different , and i`m pretty sure the doors are the same as a 10-30 series. does anyone know if the cab is the same? if not , how is it different
duallyjams 01-06-2013 08:23 PM
Re: cab question?
As far as I know they are the same.
jdl71 01-06-2013 09:05 PM
Re: cab question?
I believe the floor is flat in the center, no hump or something like that. But they will work without too much trouble.
southern parts 01-06-2013 09:18 PM
Re: cab question?
i thought it was the same. this truck is a 60 or 61 C-70 fire truck with with 3120 original miles on it. it has been kept inside until 2 years ago. all the sheetmetal is straight and rust free, 4 or 5 bolt holes in the roof still holding the big red light on. 348 cid 4 barrel, full gauges(no tach ) not mine ,yet.
Captainfab 01-07-2013 01:31 AM
Re: cab question?
The floors are completely flat across, no hump, and there is an extra brace across the firewall/toe board area. Otherwise they are the same including the doors and hoods.
63sbssbbw 01-07-2013 10:28 AM
Re: cab question?
Inner fender mounts are also different,but they're just bolt ons(unlike the '64-'66).
so it's an easy swap
T
Hmmm..flat floor....Toronado front clip?? lol
aerotruk63 01-07-2013 11:50 AM
Re: cab question?
Inner fender lower attachment brackets are different. C10's is much shorter but bolt in the same location as the C70.
In the picture below you can see the spot welded in reinforcement bracket that has to be removed that straddles the transmission tunnel. The High Hump black section as well as the sandblasted forward section were saved from another cab. A lot of work to remove the reinforcement bracket. Also an additional hole, beside the seat on the drivers side, between the seat mount and door frame,for the vent for the power brake booster. Possibility of an additional hole for the wiring for the external fuel tank.
https://lh5.googleusercontent.com/-d...0/DCP01100.JPG
