Wiring harness firewall bolt
Hey guys I am replacing my dash, need to disconnect my wiring harness, I can't find the right socket to fit on the bolt that holds the under hood harness to the block where it comes through the firewall, anyone know what it is?
Re: Wiring harness firewall bolt
2 Attachment(s)
Mine's 1/4". There's tar like material inside holding it together also. You have to persuade it to come apart even after removing the bolt.
Attachment 1057044 Attachment 1057045 |
I found the right tool, on my 2000 it was a allen head. Thanks though!
Yeah I ran into that on my 97 GMC. Of all things, an allen head bolt in there instead of a regular hex head bolt. And in a place where you cannot see the bolt, just have to feel for it. That's BS right there.
hate to dig up and old thread, but can this harness be separated, for example separate the light harness plug and the engine plug from the connector?
I have installed a carb 350 and want to clean up the wiring that isn't being used Thanks |
| All times are GMT -4. The time now is 08:53 AM. |
