-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   s10 rear (https://67-72chevytrucks.com/vboard/showthread.php?t=566805)
Chris. 02-18-2013 07:48 PM
s10 rear
I have basicly decided to go with a s10 rear my front end is 5x4-3/4 and I am going to use a T-5 trans I am wondering what is the best s10 rear to go with?
Thanks,
Chris
swizzlestick 02-18-2013 08:16 PM
Re: s10 rear
if you got an AD and want s10 rear most use 4x4 rear because its wider than 2wd rear. come in disc or drum and if you get g80 its limited slip
swizzlestick 02-18-2013 08:24 PM
Re: s10 rear
some say zr2 is the rear you want but others say its too wide
Chris. 02-18-2013 08:31 PM
Re: s10 rear
Yes the truck is a 50. Thanks for the info, does the year matter can it be a 4x4 s10 blazer too how can I determine the g80
swizzlestick 02-18-2013 10:42 PM
Re: s10 rear
g80 code can be found in glove box on rpo sticker. the other "g" code will tell you gear ratio. as far as I know s10 rears only come in three widths 2wd,4wd,zr2 body and year don't matter. all info I provide should be considered wrong until proven correct!
Chris. 02-19-2013 02:29 PM
Re: s10 rear
