-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Wiring (https://67-72chevytrucks.com/vboard/showthread.php?t=567173)
rondog4416 02-20-2013 11:30 PM
Wiring
I need to know where some wiring goes in engine compartment, there is a round plug with a light green and a dark green wire I think temp sensor ? The other is a dark green wire with two clips on the end ,any help would be great. Thanks Ron
jbclassix 02-20-2013 11:43 PM
Re: Wiring
Got any pictures? the temp sensor is a single wire (green I think) with a flat blade spade connector. The 2 wire with a round one may be reverse switch.
rondog4416 02-21-2013 01:22 AM
Re: Wiring
I will get pic's tomorrow thanks Ron
LockDoc 02-21-2013 11:13 AM
Re: Wiring
A little more info would be good too. A/C or no, year of truck, six or V-8, ect. The wiring can be different for every configuration...
LockDoc
rondog4416 02-23-2013 03:58 AM
Re: Wiring
It's a 1972 v-8 turbo-400 no a/c
LockDoc 02-23-2013 04:03 PM
Re: Wiring
How big is the round connector? Sounds like it might be the tail light connector but it would have four wires to it, Light Green, Dark Green, Yellow, and Brown and is about 1 1/8" in diameter.
The only single Dark Green wire I know of without A/C would be the temp sensor but I've never seen one with two clips on the end of it.
Like jbcassix mentioned, pictures would really help on this one.
LockDoc
jbclassix 02-23-2013 05:24 PM
Re: Wiring
I cant think of anything on the engine other than ac for the single green. What about lighting or fan?
rondog4416 03-18-2013 02:54 PM
Re: Wiring
Sorry it took so long to get pic's but here they are Hope someone can help me figure this out !!
rondog4416 03-18-2013 02:56 PM
Re: Wiring
Here is the other
BB72CHEVKT 03-18-2013 03:08 PM
Re: Wiring
horn
vectorit 03-18-2013 04:25 PM
Re: Wiring
The first one is your temp sending unit wire.
The second one I am not sure about, but I don't think it is for the horn. Since the horn needs only one wire, and the horn has a male blade connecter.
BB72CHEVKT 03-18-2013 04:42 PM
Re: Wiring
I thought the first pic might be the horn.
jorgensensc 03-18-2013 10:47 PM
Re: Wiring
It may be the jumper for hi/lo horns. Mind has a green jumper between them.
rondog4416 03-20-2013 10:10 PM
Re: Wiring
Thanks guys that helps me out a lot !! Now to get back on it and go for a ride !!!!
jorgensensc 03-20-2013 10:20 PM
Re: Wiring
Is the second one the turn signal wiring? The one that goes through the core support the the turn signal with pigtail connects to?
Burb 03-22-2013 11:19 PM
Re: Wiring
That was my thought for the second one ...the engine side for the front turn signals should have one on the other side as well
rondog4416 03-28-2013 11:52 AM
Re: Wiring
in the second picture there is only one of these so im thinking temp sender thanks again for the help ron:gmc2:
damianbryand 05-04-2013 03:05 PM
Re: Wiring
The second wire has a two prong connection that fits perfectly on the drivers side of a turbo 400. Not sure if thats where it goes but the exact length runs directly to the two prong (if you have one) connection on the tranny. I'm have the same wire running and I'm trying to figure it out as well.
