Static Drop--Ride Height
First of all, Im planning a 2 1/2 / 4" drop on my project truck.
Today I was fabbing the brackets for the rear mount fuel tank and I had a scary thought--- "will the weight of the fuel and tank (aprox 150#) mounted behind the axle cause the truck to drop further than the 4" Im looking for"? Supposedly with the drop Im planning the truck should sit nearly level--but now Im wondering if I should go with a 3" spring due to the extra weight? The thought is scary because I have already bought the new rear springs!! Anyone have any experience or thoughts with this? |
Re: Static Drop--Ride Height
Just find someone who weighs around 150 pounds and have them sit on the tailgate, if it squats too much then you'll know.
Posted via Mobile Device |
It is going to depend on how much tension your springs have. I would think new springs should be fine, especially with only having a 4 inch drop.
I have a 4/6 drop on my truck. I haven't put in the c notch yet, but I haven't had the axles hit the frame yet. I hauled 4 mounted tires in the back with no problem. I would think you should be fine, but you won't know till its all put together. John |
belair, post a pick when your done please. I have the springs to do the same 2.5/4 drop with rear tank and want to see the look. Thanx kevmac
Will do kevmac-----but it will be several months before I get her back together!! Right now she is occupying two bays of my shop and a storage trailer!!
If it squats, just trim your front springs till you get the look you want
I wouldn't sweat it too much.It's not going to be a "real" 4 in drop.The original springs have probably sagged a bit.I think I got about 2 3/4 out of my 4 in drop springs.Just something to keep in mind.2 1/2-4 drop pretty much leveled my panel. It had a pretty good rake before but that may be because the passenger front spring came out in 3 pieces.
Normally I want the full 4"----but Im thinking if the fuel and tank (and later a tonneou cover is going to add weight which could cause additional drop--then the 2 3/4" is a good thing!!
If you have a coil rear its way easy to raise it. Longer bolts and a piece of plate the desired thickness with a hole in it for the spring to rest on. You could even make practice plates from plywood to figure out how thick you want them to be.
OK--gotcha ! Where mines at now is totally unknown---the p o heated the rear springs and claimed he had a 4" drop (sorta). Im redoing both front and rear--drop spindles in front and stock springs and 4" (?)drop springs in the rear.
Im not sure how much sag would be caused on new springs with the additional 125-150# on the rear. Id rather have a slight rake than a squatter! I could still trade out the 4's for some 3's since they are still in the box. |
