Do I have to grind to fit 16" aluminum?
So I've read the threads and articles about grinding calipers to fit 15-inch wheels. There is a really good article and tutorial about grinding the Dana 60, but I haven't found any really good pictures and tutorial for a Dana 44 (or Corp 10-bolt, since they use the same hardware on the outside).
But what about 16-inch aluminum rims? I don't have a set in front of me, so I can't tell if the 16-inch aluminum has a larger ID than a 15-inch steel. Right now, I have a 15-inch steel and they don't fit, they require a wheel spacer to clear the caliper. Anybody have experience or thoughts on 16-inch aluminum rims? |
Re: Do I have to grind to fit 16" aluminum?
No problems on mine, they're 16".
16" aluminum rims will clear fine.
What's the offset (or backspacing) of these 16-inch aluminum rims that you guys are using? My current rims stick out really wide, they only have about a 2.5 inch backspace, another half inch and they would clear the caliper even though they are only 15-inch wheels.
