Parting 72 Chevy Cheyenne Super Tow Truck
I've decided to part my Big Block tow truck. Its cool, but I don't think a 3/4 ton coil spring truck is ideal for towing. This tow bed belongs on a C30 chassis. I will be pulling apart in the next couple of days. All of the sheet metal is sold including hood, fenders, doors, glove box, seat, and seat belts. Please respond in thread to avoid confusion. Post office money order preferred, paypal accepted (you cover fees)
Thanks, Ray Wrecker bed...$500 I don't think it will fit in a medium flat rate box. 402 long block good runner...$400 local carb runs, but needs rebuild...$62 shipped SOLD air cleaner holes drilled in underside...$15 plus shipping 72 alternator brackets...$85 shipped crank, water pump pulleys...$62 shipped SOLD power steering pump, resovoir, brackets (missing small bracket, non factory small bracket included)...$150 shipped SOLD Big block fan shroud good shape only a couple small nicks and small tear at bottom...$75 shipped brake booster, m/c, prop valve, brackets good working cond...$75 plus shiping SOLD woodgrain gauge cluster driver condition...$40 plus shipping Big block A/C brackets...$220 shipped 72 Big Block engine towers, mounts, clam shells...$200 shipped SOLD |
Re: Parting 72 Chevy Cheyenne Super Tow Truck
5 Attachment(s)
pics
2 Attachment(s)
2222
Do the Fender Emblems Show Cheyenne30?
No. They are Cheyenne 20.
Thanks, Ray |
I am looking for several a/c components. I need the diverter box that's under the dash, the vacuum canister, air shut off valve with the actuator (located just on top of the ac/heater box, engine bay side) shipped to 90713
I'd like to see a few more pics of the gauge cluster when you get it pulled. Thanks
Posted via Mobile Device |
I'll get in line behind Brian for the gauge cluster.
How many grooves on the pulleys?
oil pressure guage line? (From back of guage to engine) Spark plug heat shields? Th400 kickdown bracket, switch, harness? Plus the alternator brackets. Let me know what you all have. Package deal shipped to 58265? Posted via Mobile Device |
good morning Ray,
how about the mirrors? condition and shipping to 48001 also looking for 1 or 2 green armrests if the vinyl isnt worn through. |
Ill take carb if correct # for 72 big block. Come with choke parts too?
Condition of gauge bezel?
I'll take Dual tank switch set up. switch, placard, hardware, harness all associated metal items...
Glovebox door for sale?
Antenna? To 37148 please
put me inline on the glove box door. thanks.
Ill get in line behind Uncle for the carb if its the correct Number for a BB.
Man that is a cool old Truck!
3 Attachment(s)
I'll be out most of today, but here's a few answers.
Madness...no plug shields, kickdown is on the gas pedal, oil line is still there, 2 groove wp and 3 groove crank. nobolt...the mirror arms are straight, but they have some scuffs. I'll check for shipping. armrests were junk. uncle...carb #7042206 QA 2141 I'll include choke parts. David...I'll check the switch parts Eric..glove box is gone dirish...antenna is junk Here's some pics...cluster bezel has fading, peeling of clear film (daily driver) |
5 Attachment(s)
Chevyman...Here's some pics of ac. If you can, please circle the engine side parts you need.
Thanks, Ray |
How are the steel wheels?
Prices shipped for the following:
Th400 kickdown switch, gas pedal/bracket, wireing, and throttle cable. Big block pulleys Oil pressure line Posted via Mobile Device |
what kind of shape are the running boards in? pics? Coop
Sounds good just pm me your address. You are talking about choke parts that is on intake correct?
Ray I am interested in the fuel auxiliary switch with all related pieces that make it fuctional, also the name plate, shipped to 78552.......thanks.....dwt.
