20" wheel size???s
I have a chance to go up to a 20" steelie wheel.
When you guys go to 17", 18", 20" or 22" wheels do you try to maintain the stock wheel diameter so your speedo isn't jacked up or do you go with a tire size that looks good on the rim? Thanx in advance Dano |
Re: 20" wheel size???s
I would suggest going with a tire that works best with the truck. You can always replace the trans speedo gear to calibrate the speedometer.
think I'll go with 255/40/20's on all fours, pretty sure the rims are 8" or 8.5" wide. I'll know more after I pick up the wheels.
Where are you getting 20" steelies?
(Mobsteel wheels?) |
or might go with 17" toyota fj cruiser black steelies w/ 215/55/17's |
go with what ever is cheapest if you like to get heavy with your right foot.
