-   -   building a great looking wood bed for cheap (https://67-72chevytrucks.com/vboard/showthread.php?t=570849)
Chibueno 03-16-2013 12:14 AM
New to the community. I bought a 1966 C10 Longbed for a birthday present for the wife. Money was tight, but I am always up for the challenge. The wood bed was gone so here is what I was able to do for less than $150.00 I figured you would want to see the finished product first
Chibueno 03-16-2013 12:23 AM
Re: building a great looking wood bed for cheap
The bed is made from redwood that was found in local lumber yard. The whole family went out and picked through the wood pile to find the best pieces. her is a before pic of wood piece that will be replaced by the piece of wood along side of it.
Chibueno 03-16-2013 12:31 AM
2 Attachment(s)
Some of the products used; a table saw with a dado blade. I used a micro-calibrator to measure out the right size for dado. I found that the best tool outside of this forum was a good cordless impact drill. I was able to reuse the old metal strips. I cleaned them up with a wire brush wheel then use the rustoluem black primer and paint
Chibueno 03-16-2013 12:35 AM
The bed has about four months on it right now in the So. Cal weather. I has been through 3 rain storms so far and some very warm days.
earl84 03-16-2013 12:37 AM
Wow, that looks great.
Greg63 03-16-2013 12:37 AM
Looks really nice.
Greg.
Chibueno 03-16-2013 12:39 AM
Here is our truck that received the new bed I built
Chibueno 03-16-2013 12:52 AM
3 Attachment(s)
Here is the truck bed in the beginning and some of the stages before it was finished.
westcoast5 03-16-2013 02:26 AM
Nice!
Realnoisy 03-16-2013 07:34 AM
Beautiful job! Subscribed.
tincan1966 03-16-2013 07:39 AM
Great looking work!
aerotruk63 03-16-2013 10:02 AM
Man that looks nice.
63chevy4x4 03-16-2013 10:06 AM
Looks awsome!! how many coats of urithane did you use? did you thin it at all?
62 Barnfind 03-16-2013 11:13 AM
Your bed came out real nice. I did my bed myself also. I just couldn't see spending over $200 for pre cut wood and then new strips and bolts. By the time I finished pricing it it was over $500. Good job! Love the color!
Chibueno 03-16-2013 11:49 AM
RE: Looks awesome!! how many coats of urethane did you use? did you thin it at all?
I used three coats of urethane and applied it in thin coats and sanded between using 220 grit, then a tacky cloth to remove and dust. I did not thin product, but I did use a wide sponge brush because I was creating too many bubbles with a quality brush.
DesertCat 03-16-2013 12:07 PM
Nice job!
Did you leave the lumber at 5/4" or use a planer/jointer for the final thickness?
EDIT> Sorry, didn't think you may have got it as 1x material, doh! I am used to buying rough-cut wood...
Chibueno 03-16-2013 06:52 PM
Originally Posted by DesertCat (Post 5950624)
Nice job!
I bought rough cut 5/8 redwood and just sanded it with a Home Depot brand [Rigid] 5 inch rotary sander to get it to the smooth finish I liked. I would of used a planer but did not have access to one, that would have made the job much easier. Here is an example of the rough wood I started with:
Chibueno 03-16-2013 07:00 PM
Thanks for all the kudos, I am now looking to tackle the power steering conversion for the old 66. All the builds and the knowledge provided in these forums are just awesome.
Indian113 03-16-2013 07:50 PM
Awesome job,that's thinking outside the BOX!
61_FL_Apache 03-16-2013 08:26 PM
Very nice job!!
RANDY COX 03-16-2013 09:29 PM
Very Schweet,That Looks very nice,
socaljess 03-17-2013 08:54 PM
nice job that bed wood looks nice
rideblue00 03-17-2013 09:08 PM
Looks great!
LDO 03-18-2013 07:37 AM
That looks really clean. I noticed you didn't use any of the large bolts that secure the main boards to the frame. Did you just leave them out or use some tricky method of mounting them from underneath somehow?
Chibueno 03-18-2013 11:58 AM
I bolted the cross members to frame. You can use the original bolts from frame without going through the wood if you allow some space underneath your new pieces of wood. I will post a pic of what I did.
