Comp Cams CS XR294HR10 Retro Fit Hydraulic Roller
4 Attachment(s)
I had this cam in a Proffesionaly built 406 and it ran great, has one small nick on a lobe but have had comp here in memphis check it and they advised no problem whatsoever. 175.00 shipped cont. U.S.
Very low hours in virtually perfect condition! 295.00 plus shipping from summit. COMP Cams Manufacturer's Part Number:12-443-8 Part Type:Camshafts Product Line:COMP Cams Xtreme Energy Retrofit Camshafts Summit Racing Part Number:CCA-12-443-8 UPC:036584025191 Cam Style:Hydraulic roller tappet Basic Operating RPM Range:2,800-6,100 Intake Duration at 050 inch Lift:242 Exhaust Duration at 050 inch Lift:248 Duration at 050 inch Lift:242 int./248 exh. Advertised Intake Duration:294 Advertised Exhaust Duration:300 Advertised Duration:294 int./300 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.540 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.562 in. Valve Lift with Factory Rocker Arm Ratio:0.540 int./0.562 exh. Lobe Separation (degrees):110 Computer-Controlled Compatible:No Grind Number:CS XR294HR-10 Valve Springs Required:Yes Quantity:Sold individually. Notes:Retro-fit: Designed for early non-roller blocks. Requires thrust button and wear plate. COMP Cams Xtreme Energy retrofit camshafts are built to take advantage of the latest cam technology, to provide maximum performance. Whether your use is off-roading, towing, or street performance, there is an Xtreme Energy cam available for you. By using an aggressive lobe profile, these cams provide better throttle response and more top-end horsepower than equivalent cams from other manufacturers, while delivering increased engine vacuum. Warranty |
Re: Comp Cams CS XR294HR10 Retro Fit Hydraulic Roller
todatop
Still for sale!
bump
Does it come with the lifters?
Posted via Mobile Device |
No this is cam only.
