Project C-10 SS
Finally decided to do a build thread . I have been working on this truck for a few years now and a few revisions later.
I originally picked up the truck from just south of Tacoma since it really hard to find something in good rust free condition and that's a short box up here in the Vancouver bc area. Originally I was going to built this as a pro street truck then changed my mine after I got it able to go around the block a few times. Now I going for the pro touring look, wanting the truck to be fast and and not scared of corners. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Project C-10 SS
5 Attachment(s)
start of the single turbo set up on a 383 , with the motor pushed back and set lower in the frame rails Attachment 1082589
Attachment 1082587 Attachment 1082590 Attachment 1082586 Attachment 1082588 |
Re: Project C-10 SS
3 Attachment(s)
some more pics of the turbo set up during fabricationAttachment 1082594
Attachment 1082592 Attachment 1082593 |
Re: Project C-10 SS
3 Attachment(s)
this is what the truck was looking like without being lowered in the rear at all and with drop spindles and cut springs. then i tore the whole thing down and started boxing up the frame. Attachment 1082595
Attachment 1082596 Attachment 1082597 |
Re: Project C-10 SS
5 Attachment(s)
the frame all boxed up and some custom crossmemeber action and bracing Attachment 1082602
Attachment 1082601 Attachment 1082599 Attachment 1082598 Attachment 1082600 |
Re: Project C-10 SS
3 Attachment(s)
getting it all back together again then some shock towers were built after the box was put on and then tubed out the box
Attachment 1082603 Attachment 1082605 |
Re: Project C-10 SS
4 Attachment(s)
Re: Project C-10 SS
5 Attachment(s)
after i got the truck box all tubed out i kinda put it on the back burner and didnt touch it much. got busy with mountain biking and turning my 2001 silverado into a beast of a truck. it had the 4.8L in it ended up getting some 18s wrapped in 33s for. put a cold air on it it, chipped it, headers and built a sick exhausts for with no cats. you could hear this thing long before you couple see it. also it had a dixie horn on it and a hidden winch,
that truck went through hell and back, it went places and did stuff some trucks would never dare to do , but one day up at the local redneck stomping grounds it got it high centered and when jacking it up the the jack slipped and punched a hole in the oil pan!!!! good thing i am metal fabricator by trade :metal:Attachment 1082611 Attachment 1082610 Attachment 1082612 Attachment 1082613 Attachment 1082614 |
Re: Project C-10 SS
2 Attachment(s)
i had that truck for about 3 years then went out and picked a 07 denali for a wicked price and put a cold air on it and chip then did headers and true dual exhuast with the dynomax x chamber muffler. its one loud truck :) sounds like a offshore racing boat. plus gotta have 22s on it. i plan on puttin a 2/4 drop on it around this summer then if i dont get bored of it switch it all out for air ride. heres a couple pics of the denali and the silverado which i sold to my dad for working up north in the mines.
i done alot of work on the c-10 i just gotta get the photos off the the ipad since i cant figure out who to post more then one at a time on it.Attachment 1082616 Attachment 1082615 |
Re: Project C-10 SS
Awesome build. Nothing like boost...except...more boost.
Re: Project C-10 SS
Looking forward to seeing the turbo 383 C10. Sounds like an intense build.
Re: Project C-10 SS
WOW...looks like a BEAST !
Re: Project C-10 SS
Sweet, love the turbo set up!
Re: Project C-10 SS
thanks for the comments guys !
here are some specs/ what i have done to the truck The chassis to start. I fully boxed the frame and built my own front crossmemeber and bracing to stiffen it up, built a rear shock tower for coil overs, welded the seam on the trailing arms with a cpp track bar, the motor sits almost 5 inches back and about 2 inches lower then stock location. it has a one piece steel drive shaft in it right now and a 12 bolt which is still stock. I will wait till i blow it up to upgraded the parts in it.also add hydroboost to it and will get some big brakes so it can stop. For the motor its a 383 stroker that makes about 425hp off boost, planing on to run 5 to 10 psi until I build up a boost block that I can crank to 30psi. Got a custom build blow thru carb from quickfuel ( one slick carb ) The turbo is a Holeset HX35 off a 6.7L cummins diesel switched it over to external wastegate and running a 50mm blowoff valve and running MSD pro billet distributor with a 6al-2 box. all that is back by a 700r4 thats built up and 1800 stall on it. I planing also to add meth injection aswell For body mods so far i tubed out the box to fit the 20s i will run on it down the road. the tail gate has been gutted and welded in with a rollpan. built a new bluck head for when i build a power actuated aluminum tonneau cover so its a nice tight fit , fuel cell and bat box are mounted in the box. Shaved the cargo light,fuel filler hole,fire wall,and any other little hole to give it a clean look. i still gotta shave the shave the cowl smooth and cut weight out of the rad support and going to pie cut the hood to get the slant look of the 67 hood but with a 72 grill. |
Re: Project C-10 SS
3 Attachment(s)
here some more pics of the most recent work i have done on the truck , cleaned up the fire wall even more. i want to have it so you see no wires in the engine bay at all.
Re: Project C-10 SS
3 Attachment(s)
some of the interior work so far, going to run a double din for the stereo and i will get my dad to build the centre console and sub boxes since he use to build sound comption cars back in the day.Attachment 1083054
Attachment 1083056 Attachment 1083055 |
Re: Project C-10 SS
engine sounds mean. Just wondering what how fast that turbo will spool and where it will start making the power. When you are done, Dyno numbers would be excellent.
Re: Project C-10 SS
I have had it running before with the turbo on and it's like boost on right away by the time the converter grabs
Re: Project C-10 SS
Today I got the cowl shaved and cut weight out of the rad support
Attachment 1084002Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: Project C-10 SS
Little more progress on the truck . Been side track with getting ready to move to a new place the last couple weeks . I got the front sheet metal all put back on and finished the engine bay wiring and kept them all hidden ( good luck finding wires:metal:) also got the rad and intercooler mounted and the air filter for the turbo intake . Attachment 1090303
Re: Project C-10 SS
Air filter set up Attachment 1090304
Re: Project C-10 SS
Top view of the filter Attachment 1090306Posted via Mobile Device
Next I gotta figure out a cool way to mount the Trans and oil coolers then run the line and mount the fuel reg Posted via Mobile Device |
Re: Project C-10 SS
great progress
Re: Project C-10 SS
Love it!!
Re: Project C-10 SS
Real nice !!!
Keep it up |
