-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   IL April Fools Swap Meet in Sauget, IL April 7th (https://67-72chevytrucks.com/vboard/showthread.php?t=573161)
Todd68Chevy 03-29-2013 09:31 PM
5 Attachment(s)
I am heading to the 30th GCS Ballpark April Fools Swap Meet in Sauget, IL on April 7th. I am going to be set up as a vendor but going to limited on hauling space and thought if someone was going and needs something I might be able to bring it with me. I mail smaller items but I really do not have the time or abilities to ship these large items at this time. Let me know what you need and I will see if I have it and can get you a condition and price. I do work all week and it might take me some time to get you answers/ pictures. I do not have room to bring it all so let me know what you are interested in. I will only gaurantee to hold an item with money down.
****Parts can be picked up in Shelburn, IN also if that is better for you then at the swap meet*****
****I am also planning on being at the Class Pack Swap Meet at the Effingham County Fairgrounds in Altamont, IL on **** April 13th http://classpack.com/swap_meet ***
1967 Chevy/ GMC A/C dash $110.00 cut at the dash pad
1968-72 non A/C Dash $80.00 cut outside the windshield weld area
1967-68 Chevy Grill - bare $60.00
1968 paintable GMC grille $75.00
1969-1972 right front fender- some rust in the front pocket but repairable $30.00
1969-1972 Left front fender- some rust on the wheel well arch- pocket pretty solid $30.00
1971-72? Woodgrain tailgate panel with letters- drivers condition $80.00
1972 plastic door panels $25.00 and up, some with woodgrain
1967-71 metal door panels $25.00 and up
1967 Chevy/ GMC rust free right hand door- 2 available $135.00 each O.B.O. or $240.00 for the pair. no rust but does have dents
1967 Chevy Small Back window cab section $75.00
1969-1970 Chevy Hood surface rust under the front lip but solid $60.00
1971-1972 Chevy, 1969-1972 GMC Hood rust free but few dents $60.00
1967-1968 Chevy/ GMC Hood needs some repair to the front $80.00
1967-1972 Rear Trailing arms- minor rust in between but the sides check solid SOLD
High Hump bolt in transmission tunnel with hole $40.00
Bench seat- cover poor but the foam, springs, frame all look good SOLD
Dash Pad- usable shape but has been recovered $35.00
Set of 4 GM Truck Rallies with NO caps, tires or rings 6 lug 15x7 $100.00 each or $350.00 for all 4
Pair of GM Truck Rallies with NO caps, tires or rings 6 Lug 15x8 $55.00 for the pair
Set of 4 GM Truck Rallies with NO caps, tires or rings 5 Lug 15x8 $110.00 for all 4
Set of 4 Black Mod wheels WITH spinners, no tires 6 Lug 2- 15x7 & 2- 15x8 $125.00 for all 4
Manual Transmission Bell Housing $30.00
Automatic Transmission Crossmember $40.00
***************Found more parts today 3-30-13*************
Automatic brake pedal assy. $25.00 each
Clutch/ Brake pedal assy. $35.00
Brake booster brackets, used booster and master cylinder (conditions unknown) $55.00 each
1 1/16" Front Sway bar, bushing brackets and frame brackets SOLD
1971- 1972 Chevy Grill- Decent condition- some dings and couple cracks in the inner $80.00
Cowl panels -- $20.00 with ant. hole (several available)
$45.00 with antenna delete (2 available)
Many, Many more parts.
I do not have very much good sheet metal other than what is listed and I have no 4wd items (other than the high humps listed above)
I am also looking for a rust free 67-68 Chevy core support. If you have one you would like to sell, please let me know a price and pictures.
After Friday evening April 5th, I will be away from email. You can PM me for a phone #
Thanks for looking. I do not have room to bring it all so let me know what you are interested in. I will only gaurantee to hold an item with money down.
72 tigger 03-29-2013 09:39 PM
Re: April Fools Swap Meet in Sauget, IL April 7th
Todd, how much for the pair of black door panels? Hope you can sell some stuff! Kirk
Todd68Chevy 03-29-2013 09:59 PM
5 Attachment(s)
Hi Kirk, Have not seen you around for awhile. Hope everything is going good. I decided to try a different swap meet this year. Do you need anything picked up over in St. Louis this time? LOL
Black pair: Nice plastic, woodgrain has slight wear, drivers side woodgrain panel dented, passenger side woodgrain panel is damaged around the door handle hole. $100.00 for pair Let me know if you want more pictures -PM sent
72 tigger 03-29-2013 10:06 PM
Todd, I'll take them. PM me your address & I'll get a check coming your way. Could you store them in the bus until I can pick them up?? Doing well- thanks for asking! Thanks, Kirk
Todd68Chevy 03-29-2013 10:27 PM
Black woodgrain door panels sold pending payment. I will see if I can find a place in the bus for them. PM returned, Thanks again.
I guess I should have said that parts can be picked up in Shelburn, IN instead of at the swap meet if it work better for you. Thanks
BAT 03-29-2013 10:37 PM
I'm interested in the 69-70 hood and possibly the bell housing.
Todd68Chevy 03-29-2013 10:43 PM
Originally Posted by BAT (Post 5979533)
I'm interested in the hood and possibly the bell housing.
I can get more pictures. Which hood? 67-68, 69-70 (has hood emblem- pictured above) or 71-72 (no hood emblem) ?
Todd68Chevy 03-29-2013 10:47 PM
5 Attachment(s)
Ok, Here are a few pictures. I can get more.
Dave 03-29-2013 11:07 PM
Todd,
Could use the high trans tunnels, brackets that mount on the trans cross member for e-brake cables, to start. Road trip perhaps? LMK, thanks Dave.
Todd68Chevy 03-30-2013 07:10 AM
Originally Posted by Dave (Post 5979622)
Todd,
I will check on the brackets, I am not sure if I have them. I might have a box to fit a high hump in so I might be able to ship one. I will get pictures and let you know. Thanks
Dave 03-30-2013 07:43 AM
Ok, LMK when you can.
Sammy 03-30-2013 11:00 AM
Todd, you have high humps without holes? And a price if you do.
Todd68Chevy 03-30-2013 09:43 PM
5 Attachment(s)
Sorry, I did not get anymore pictures of the hood today. Here are a few of the bell housing. I did notice that the lower starter bolt hole is broken out. I do not think it would be an issue if you use a block mounted starter. I will go $25.00 on the bell housing, Thanks
Todd,
Here are some pictures of the best high hump I have. I have 3 transmission crossmembers and none of them have the parking brake brackets. Thanks
I have one but was planning on keeping it for a possible future project. Thanks
Todd68Chevy 03-30-2013 09:44 PM
3 Attachment(s)
A few more pictures.
Dave 03-30-2013 09:55 PM
Todd,
I was looking for one that is for an auto. Thanks for checking on the brkts for e brake and pics. LMK, if you come across a auto high hump, though.
I think someday I need to come down your way and pick up a few things. I'm also looking for 70-71 black door panels with woodgrain.
Thanks Dave.
Todd68Chevy 03-30-2013 10:06 PM
Originally Posted by Dave (Post 5981452)
Todd,
Thanks Dave.
The only auto 2wd high hump that I have, I was wanting to keep. I just brought home another 72 today and have not checked but I do not think it is a high hump (just a sb auto). I have some plain metal panels but no good covered ones at this time. Where are you in NW Indiana? I actually come up that way when I go to my buddy's house in MI. He lives in the Benton Harbor area on MI. Thanks
Dave 03-30-2013 10:10 PM
Michigan City, you drive right by me:lol:. The 72 you brought home, any details or pics?
Todd68Chevy 03-30-2013 10:20 PM
Yes, I come up I65 to 80/94 and then around into MI on 94. My next trip that way will probably be Memorial Day weekend. I go up a several times a year. If you have seen my build thread on my 46 Chevy, That cab is up there being worked on.
The 72 is a pretty rough project that the guy gave up on and called me wanting to sell it. I did not get any pictures today but the body is pretty rough. It has been disassembled but was a SB, Auto, PS, PB, A/C truck and parts from another truck he was using for parts. Still going thru stuff but not a lot of options or good stuff. Just trying to keep some of the parts out of the scap yard and being sent to China. I am up to 8 trucks sitting around but the barn is full so if I disassemble them I have no where to put the parts. LOL I guess I need to sell more. LOL
Todd68Chevy 03-30-2013 10:30 PM
3 Attachment(s)
1 1/16" Front Sway bar, bushing brackets and frame brackets $45.00
Todd68Chevy 03-31-2013 07:28 AM
A few more parts:
$45.00 with antenna delete (1 available)
Sammy 03-31-2013 10:18 AM
Todd. Last year you had such a real nice 67/68 core support you let go of. I have let things go also..later regretted.
Maybe no bad tornadoes to take out windows this year!
Todd68Chevy 03-31-2013 10:30 AM
I am hoping for good weather but you never know at an outdoor meet. Hope to get to talk to you guys again this year. I am in hunt for parts for my 46 so I have more reasons to go.
I have definately regretted getting rid of stuff but that core support last year was good but not that nice. It looked really good until you seen the one side had been repaired with fiberglass where the inner fender bolts on. I have one that is rusted in the same place that came be repaired correctly and be better than than but if I can find a rust free one, I would rather have that. I do not even need one unless my truck gets wrecked or I take it apart and redo it. I just know that they are not making them and they are just going to keep getting harder to find.
70CHEVYBB 03-31-2013 11:26 AM
are all 4 u brackets with the bar. I will take the swaybar if they are. I would like the best of thecowl panels with a antenna hole. I will be at saugnet swap to pick the items up. do you take paypal?
BAT 03-31-2013 11:39 AM
I'm going to pass, thanks anyway.
WETOWM 03-31-2013 12:33 PM
Do you happen to have a original tailpipe hanger for a rear leaf spring truck
