How do I fix this?!
http://i270.photobucket.com/albums/j...0FD38C9762.jpg
Drivers side is rusty and has the hole and the passenger side is fine but also has a speaker hole :waah: how do I fix this? Do they make patch panels for this part of the truck? Posted via Mobile Device |
Re: How do I fix this?!
That is one big a** hole. Have fun with that.
Weld in some sheet metal?
Prob going to have to make my own patch panel and cut the whole section out
I'd cut it at the door jam leave about a inch so you can bend it down to have a lip to weld on to.
It's just a flat piece, shouldn't be too hard to make. I believe in your skills!
The flat parts the easy stuff the rust at the bottom is my main concern as the floor joins the side and is spot welded underneath right?
Its odd it rusted out that low and no where else around it,I guess you'll find out once you open it up how much rust is hiden in there.
I replaced my kick panel, floor and rockers. Here's my thread might help ya.
http://67-72chevytrucks.com/vboard/s...d.php?t=433819 Posted via Mobile Device |
