-   -   broke my u joint (https://67-72chevytrucks.com/vboard/showthread.php?t=573531)
hopped up 03-31-2013 11:14 PM
broke my u joint
[IMG]http://i1099.photobucket.com/albums/...ec214cf874.jpg[/IMG]
Broke a joint yesterday,is there a fix for this rear driveshaft or do I need to find a new one? Anyone have one laying around? Or and l.a. Area guys know where I can get this one fixed? Thanks a lot guys
donthekawguy 03-31-2013 11:23 PM
Re: broke my u joint
The end is toast. Try a wrecking yard for a new one. If you can't find one you could take it to a driveline shop and have them cut off the end and put a new one on. Not sure if that can e fixed because the fitment is so tight.
juanz1947 03-31-2013 11:24 PM
ouch look like you need to get another one should not be flat
hopped up 03-31-2013 11:27 PM
Yeah that's what I was afraid of. I went to 3 different junkyard today and only found 1 60-66 c10. And of course the driveshafts were gone :(
akaupp 03-31-2013 11:34 PM
Not sure where in L.A. you are, but I had great luck with Drivelines, Inc. They are in Mission Viejo, in Orange County.
hopped up 04-01-2013 12:18 AM
The weird thing is this isn't even the side the u joint broke off. This end was still hooked up to the center bearing carrier. Can't fig out how it would get damaged like that
Sharps40 04-01-2013 05:29 AM
hopped up
I have a 1964 C10, SBSS drive shaft, I assume its the same. It'll be about a bazillian dollars to ship an entire drive shaft to CA but I can cut one end off and ship it via USPS flat rate box and you can have it welded to yours and rebalanced.
I have the entire drive shaft for sale here for $30 local pick up. I think Med flat rate runs about $12 to anywhere now. So, I'm sure we can figure out a price for just the yolk or cross end for ya.
Shoot me a PM if a 64 is useable for ya.
MikeN 04-05-2013 09:16 AM
I broke the rear u-joint on my 69 Chevelle at the dragstrip Saturday. It ruined the end of my driveshaft just like yours. That damage is from the driveshaft getting yanked around when the u-joint broke. Any local driveshaft shop can easily cut off the damaged yoke, weld on another, intall a new u-joint, and balance the entire assembly. It would in all likelihood be well under $100.
I had a whole new heavy duty driveshaft made Monday for my Chevelle at the local driveshaft shop. It was $250 end-to-end.
