-   -   Opinions on running 35s with tbi 454/th400? (https://67-72chevytrucks.com/vboard/showthread.php?t=575290)
Wellgeo03 04-12-2013 12:19 PM
2 Attachment(s)
Looking at ordering a lift and some new tires for my new crew. I would like to run a set of 35s. It has 3.73 gears with a G80 in the rear.
It currently has the stock size 235s on it and the power is just OK. How badly will the 35s hurt the power?
I am currently torn between a 4" and a 6" lift for it. On my other crew, (86 custom deluxe) I figured a 4" would be fine to run 35s, as I am running 33s on it right now at stock height with no problems. This new crew (90 sliverado) sits almost exactly 1 inch lower than my 86 both front and rear even though both have the same GVW rating and spring count. The 86 is a 350/sm465, the 90 is the 454/th400.
What would you recommend?
Wellgeo03 04-12-2013 08:25 PM
Re: Opinions on running 35s with tbi 454/th400?
Has anyone run 35's with 3.73 gears and a 454?
Where is the peak torque of the TBI 454s?
dieseldawg142 04-13-2013 12:02 AM
you would think a 454 should have no problems with 3:73's & 35's. my blazer had a 400sb, 3:73's, & 35's. was'ent a speed demon, but was'ent no slouch either. my crew (also 454,T400) has 38.5's with 4:56's, great off the line, but horrible on the freeway. i would stay with the 3:73's, if it drops your powerband too much, try 4:10's. would'nt go lower than that with the T400, kiss away any fuel mileage you think your getting!
Rubble 04-13-2013 01:12 AM
You should be fine with 35s & the 454.My 86 has 35s with a mild 350,465 & 4:10s Really good combo.Good off the line & not too bad for highway cruising...2500 rpm @ 100kms.
b454rat 04-13-2013 09:02 AM
I ran a 454/400 with 40' boggers with 3.73s, and could still lite the tires up going around a corner....IMO it's a good compromise, what I love bout big blocks, lotsa torque!!!!!
http://imageshack.us/a/img106/7391/00125apu2.jpg
Redcap 04-13-2013 02:29 PM
I'm running 35x12.5s on my K20 and 4.10 gears, which are a little too low for my 454 right now (I could pull a house down), but will be perfect once the Ranger OD goes in.
Joesjunk 04-14-2013 11:57 AM
I have a stock original 454/400 with 3:73 gears and 35's and it runs perfect.
Wellgeo03 04-14-2013 12:25 PM
Great! Thanks for all the feed back guys!
I can't wait to get this new truck up in the air a bit and get some 35's under it!
Joesjunk, what are you running for a lift?
Joesjunk 04-14-2013 01:00 PM
its a 4" lift
weider1717 04-14-2013 02:14 PM
Are you 100% sure thats just a 4" lift? looks like a 6" those 35's have plenty of room looks great!
Joesjunk 04-14-2013 03:11 PM
I thought it might be a 6" lift myself, but the springs have part #8002 rough country, I looked it up and it says 4"???? But I must say it pretty tall, taller than my 71 with a 4" lift and 35's
b454rat 04-14-2013 09:29 PM
It's because 1 tons have a 2" taller frame than half and three quarters do.
Joesjunk 04-14-2013 10:07 PM
Thanks for that info!!
