Name that part
4 Attachment(s)
These I believe came of my 2wd 75 stepside 350/350.
They match the bolt pattern on the buckets for the motor mounts but what are they for? I did clean them up but are they needed when I replace the 350 with my 468? Thanks |
Re: Name that part
Motor Mounts
V8 Motor Mounts Not for this truck I would guess earlier model year. Thats my guess and i'm sticking to it.. |
Re: Name that part
They're not motor mounts, they're bracing brackets used on '88 - '98 4WD trucks. There's a rod that goes from the corner hole back to the bellhousing/tranny where it bolts in place on each side. They're in place to help brace/strengthen things since there's not a full crossmember in 4WD trucks. The engine that's in the truck probably came from a 4WD donor...or somebody used the wrong mounts and used these as spacers. You don't need them.
Re: Name that part
And a funky Newcastle.
Posted via Mobile Device |
Re: Name that part
Re: Name that part
Re: Name that part
Those braces were also used in square bodies. The bellhousing dust cover will be cast and it will have two bolt holes spaced approximately the same width as your engine oil pan. Pretty sure the 700R4 and the 4L80E use them.
| All times are GMT -4. The time now is 06:38 AM. |
