Will this fuel pump work
I'm planning on swapping a 5.3 into my 54. I have a 01 Blazer tank that I picked up a while back that I was planning to use to relocate my fuel tank. Was wondering if this pump with flow enough for the 5.3
Electric Fuel Pump New With Sending Unit Chevy Olds GMC Jimmy Blazer 2004 Description / Notes: "Martins Fuel Pump -- MARTINS FUEL PUMP MODULE ASSEMBLY, ELECTRIC, NEW Martins OE Comparable Fuel Pump Module Assembly - Brand New is your dependable replacement product for your damaged part; guaranteed NEW - not reconditioned. This new fuel pump is ideal for your restoration needs at an affordable price. These products are covered with 1-year limited Martins warranty! " Condition: New Flow rate: 45 to 55 gallons/hour Operation: Electric Anticipated ship out time: 1-3 business days Quantity sold: Assembly Product fit: OE replacement Recommended use: OE comparable Mechanism: Rollervane Fuel sending unit included: Yes Pressure sensor included: Yes Notes: 12 volts |
Re: Will this fuel pump work
bump.
The stock 01 blazer pump will be enough to feed the 5.3
Posted via Mobile Device |
Thank you for the reply. I know I ask a lot of questions but I'm trying to only build my truck once lol.
