-   -   V6 305 HOLLEY SWAP air cleaner ?? (https://67-72chevytrucks.com/vboard/showthread.php?t=577723)
Matt's k5 04-27-2013 11:16 PM
I finally ordered my Holley 500!!! for my 62 305, but i was wondering on size and type of air cleaner, i was thinking of this one
http://www.ebay.com/itm/130720155158...84.m1423.l2649
what you guys think? would it work? i just want a simple chrome one not to big i think the 14'' looks too big ? thank guys! pics will be up soon !
MusicMan70 04-28-2013 01:41 AM
Re: V6 305 HOLLEY SWAP air cleaner ??
That will look good atop your Holley 500! It will be a nice upgrade too.
oldno7 04-28-2013 08:39 AM
Just curious is the 500 good for all the v-6's or just the 305 I just ran across a couple of these 478m and 401m and with these being bigger i didnt know if the 500 would be good for them. Make sure you post some pics up for us i would like to see the complete setup, and is this for your k-5
Matt's k5 04-28-2013 12:40 PM
no its for my 62
MusicMan70 04-28-2013 12:45 PM
oldno7
Posts: 418 Re: V6 305 HOLLEY SWAP air cleaner ??
Oldno7, here is a link to with info on this upgrade. Some have even adapted Quadrajets too. It would be fine to use on a 401 or 478. I believe he's using it for his 62' in his signature.
http://www.6066gmcguy.org/holley.htm
raylube 04-28-2013 04:34 PM
Hey bro knowing your truck I would modify the oil bath to make it look stock with a KN filter. I did this with mine. Also the choke cable is not long enough.
jbgroby 04-28-2013 05:14 PM
I used the low profile cleaner, you can find them at your local FLAP.
http://i1299.photobucket.com/albums/...psf965d16d.jpg
Matt's k5 04-28-2013 05:22 PM
idk i like seeing the carb more guess looks to squished i will see i orderd the 10 inch one if not i will get somethin else, but i am lucky to get the green light to do it if you know what i mean! where can i find a longer choke cable?
HEI451 04-28-2013 06:45 PM
I changed the bottom of my stock 2bbl air filter to one that was same overall dimension, but had the Holley flange sizing, then, used a K&N replacement filter and stock single snorkel top.
One thing I'd suggest when you get that filter, is to build a sheet metal air break. Simple to make, block the front 1/4th of the filter off, break mounted to the inside diameter of the air filter element, and held in place by the recesses on the filter bottom/top. Why? Fan air being forced across the top of the air horn on the carb only helps pull air OUT of the air horn as it passes over the top of the air horn, isn't being directed into the air horn/inlet, and that causes problems in drive ability.
There are commercially available air breaks for open element air filters, to help manage the forced air through the filter issues, Trans-Dapt used to have them that fit on the outside of the filter element, in the bent over lips of the filter housing.
Matt's k5 05-04-2013 11:52 PM
3 Attachment(s)
Hers is some pics of it all done!!! what you guys think?
Matt's k5 05-04-2013 11:54 PM
I LOVE IT!! LOOKS AWESOME!!! and runs so much better! i for got to take pics when i was installing it
creep 05-05-2013 10:32 AM
Very nice! The Holley 500 swap is about the best thing you can do to a 305, in my opinion anyways. I used a 14'' low profile Holley aircleaner that I had powdercoated satin black and found a Fram airhog filter that was orange to match my motor a little bit.
http://i9.photobucket.com/albums/a91...p/DSC02897.jpg
