-   LSx Swaps (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=206)
-   -   Water pump leaking on a 5.3 (https://67-72chevytrucks.com/vboard/showthread.php?t=580679)
Indian113 05-17-2013 07:00 PM
How tough is it to replace a water pump on a 5.3 in the car? Remember it's in a 92 S10! I've tightened all of my clamps and can't seem to find any leaks on the hoses, it's gotta be the water pump.
truckdude239 05-17-2013 07:49 PM
Re: Water pump leaking on a 5.3
Its not that bad if you have space
85burb 05-17-2013 09:09 PM
The leak could just be the gaskets. They have a been know to leak. Try snugging the 6 mouting bolts up.
Indian113 05-17-2013 09:11 PM
Room? Don't have a lot of extra :lol: I'm gonna do it next week it can't be too bad!
Indian113 05-17-2013 09:12 PM
Don't they use O rings for gaskets?
85burb 05-17-2013 09:19 PM
They use metal gaskets with orings built in. By the looks of it it is just a few hose clamps and one bolt and the rad it out of the way.
bohmankid 05-17-2013 09:59 PM
Super easy to replace. Just need to take off every other accessory, but I did mine in 20 minutes (in my full size truck). My water pump was bad after I finished my swap. 80,000 miles on motor.
Indian113 05-18-2013 05:58 AM
Thanks for the advice Guy's I'll update after I get it done,have a lot of Honey dos to do this weekend.
Indian113 05-22-2013 09:08 AM
Anybody know the Torque specs for the water pump bolts?
ls1nova71 05-22-2013 11:15 AM
18 lb ft
Indian113 05-22-2013 11:39 AM
Thank You! I couldn't find a chart, Hate to under or over tighten them.
Indian113 05-22-2013 06:39 PM
Got it done, No Leaky!! Filled it and refilled after it cooled down.
Thanks for the Help and advice. I have to admit I love that little truck.
68GMCCustom 05-22-2013 07:55 PM
I'm guessing a 5.3 in that little truck makes for some fun times!
Indian113 05-22-2013 08:19 PM
Yes it does, I think I might have been just as happy with a 4.8. Traction is a problem-that and a 260 lb. RIGHT FOOT :lol:
Dieselwrencher 05-22-2013 09:07 PM
I was going to say, I bet those high RPM burn outs are the root cause for the water pump failure. :lol:
Indian113 05-22-2013 09:12 PM
You would Know!
Sundrop 05-22-2013 09:17 PM
Everything is easy when you have space :lol:
