GMPP 12486570 Dual Plane Aluminum Intake for Vortec Heads SBC
I bought this intake used at a swap meet a few years ago and have not needed it, so it is time to part ways. It appears to have been run very little, if any. There are no cracks, stripped threads or other flaws. $200 shipped to the lower 48.
Paypal Ok, you pay the fees. I ship every Saturday, so please be patient. |
Re: GMPP 12486570 Dual Plane Aluminum Intake for Vortec Heads SBC
Would you trade?
Nice intake, but will pass sorry bump for ya!
Interested. I have a single plane GMPP. I am parting with.
looks like my heads have both bolt patterns...........what head mount degree is it?
Posted via Mobile Device |
well let me know when you find out the deg........vortec was different than std. chevy heads.
There are no center bolt holes on this intake like the ones found on non vortec heads. Non vortec use twelve bolts, this one uses eight.
I run GMPP FASTBURN heads that have two bolt patterns based on VORTEC heads design for obvious reasons. I just need to know the head angle degree on the product you are selling.
The intake is packed away with my swap meet stuff and i only go out to where its stored on thursdays and fridays. I cant imagine it not being compatible with any heads that use the eight bolt vortec mounting design. As mentioned above, i have bolted this intake to a stock 97 vortec 350.
Keep in mind that this intake is a spreadbore design carb mounting...ie Qjet, Thermoquad or Holley spreadbore only.....standard squarebore Holley and Edelbrock will not bolt on without an adaptor. |
I am not sure what the exact angle is on vortec intakes, but the are straight up and down when viewed on the engine. This intake has carburetor mounting pattens for square bore or spreadbore carbs. Many of the questions being asked can be answered by looking at the photo above. Posted via Mobile Device |
To clear up any confusion, the two bolt holes seen on the left side of the intake are not intake mounting holes. These are for accessory bracket mounting only.
Please note the listing title that states that this manifold fits vortec heads. Thanks everyone for the multiple bumps to the top. Posted via Mobile Device |
Please note the listing title that states that this manifold fits vortec heads. Thanks everyone for the multiple bumps to the top. Posted via Mobile Device Posted via Mobile Device |
"Intake manifold mounting surfaces are drilled and tapped for both Vortec and conventional raised port style intake manifolds." I am confident that this intake manifold will fit your heads. So much so that if it does not, i will refund tour money and I will pay return shipping if they do not. Posted via Mobile Device |
