anyone put 2 1/16 in. gauges in dash
I,m looking for threads that someone has put the 2 1'16 in. gauges [I think that is the size, close to it anyway] in through the front of the gauge panel.I found some threads where the gauges are mounted from the back but I thought the front would be easier.I don,t what to wreck a good panel
Re: anyone put 2 1/16 in. gauges in dash
i just replaced my 4 with gauges. i had to trim a little off the plastic dash face. but mounted them through the metal and clamped them on the back. you will have to open the holes a little more and offset them a bit to your viewing pleasure. but i comes out pretty good. i retained my factory speedometer and fuel gauge. so i don't know about them. i don't have any pictures handy on my work computer, but if you pm me your email i can send you some later.
5 Attachment(s)
unless you can find a gauge that's like an inch thick, (good luck!), you will have to do some trimming. did my 4 small gauges with autometers
you will have to dremel the gauge housing a bit Attachment 1118934 also have to trim the "glass" & gauge backing Attachment 1118935 more trimming on the gauge panel Attachment 1118936 wire them up Attachment 1118937 and your good to go Attachment 1118943 |
That looks slick, any way to do the speedo and fuel gauges by using the bezel itself?
Mine http://i270.photobucket.com/albums/j...31309CD1FF.jpg
Posted via Mobile Device |
2 Attachment(s)
Attachment 1119480 Attachment 1119482 |
