Headliner install
Did a search and didn't find an answer, but I know the answer is out there and
i just didn't find it. I want to add a factory style headliner and trim to a factory non-headliner cab. Can this be done? I'm sure it can, just can't find the install pics. Anything special that needs done to complete this? Pics would be great, or links to past installs maybe? |
Re: Headliner install
Sure.. I did it on mine.. not too bad, but it does require some work.. The worst part is working with your heads over your head for a extend time.
http://67-72chevytrucks.com/vboard/s...&postcount=536 http://67-72chevytrucks.com/vboard/s...&postcount=852 I found this… Hope it helps.. http://www.brotherstrucks.com/techar...LATION&index=0 |
Wow. Stared at those links for a little while. Not sure i want a headliner bad enough to go through all that work. And thank you for the informative response. |
Here's a DIY yourself link from Brothers Truck parts that I found when searching for info to replace mine: http://www.brotherstrucks.com/techar...20INSTALLATION
Just don't use Super 77 adhesive - it won't work. I tried three times. Go with the black 3M weatherstrip adhesive. Good luck. Pete |
Kinda off topic,but has anyone been successful removing the trim w/o breaking the tabs and reusing it? I changed color in my '72 Sierra but haven't touched the headliner (just don't look up). I have N.O.S. trim I'm saving till it's fully restored
I changed "interior" color w/o touching the paint...so far. I'm talking about removing my original headliner trim and reusing it for now. It seems the tabs are just plain prone to breaking no matter how careful you are...unless someone has a secret out there.
