-   The 1973 - 1991 Blazers, Jimmys, and Suburbans Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=37)
-   -   87 suburban speedo problem, any suggestions? (https://67-72chevytrucks.com/vboard/showthread.php?t=585721)
Nodnarb76 06-21-2013 01:58 PM
My 87 suburban 2wd with Th400's speedometer hasn't worked since I got it.
I have replaced the cable(s) and driven gear already. Once I replaced the driven gear, it worked for about 7 miles then stopped. Every once in a while when the truck is cold (first startup of the day), the speedometer works for a mile or so then stops.
When the driven gear was replaced I had my friend at work do it ( work at a dealership) and I didn't ask him to check the drive gear inside the transmission.
I seem to have some sort of adapter between the cable and gear housing (see pics), anyone know about it and if it would be likely to fail?
Nodnarb76 06-28-2013 05:28 PM
Re: 87 suburban speedo problem, any suggestions?
Update removed the adapter between the cable and trans.
Works great now!
68Timber 06-28-2013 09:18 PM
That adjusts the speedometer cable rpm so the speedo reads true. They work great until they freeze up solid and break a tooth when you go to drive it. You can remove it and bypass it but the speedo will be off. Check the speedo against a GPS to see where you really are at a few different common speeds.
Nodnarb76 06-29-2013 04:33 PM
Haven't had a chance to check and see how off it is. Seems to be pretty close.
When I ordered the driven gear, I ordered the gear for 32" tires, 3.73 rear end and 17 teeth on the drive gear. according to what I have read this is the correct drive gear for what I have and may not need an adapter. I'll report back when I know for sure.
68Timber 06-29-2013 06:29 PM
You should be good without the "compensator" if you changed the driven gear to what you need for your combo. How did you verify the drive gear?
Nodnarb76 06-29-2013 11:52 PM
There was a website I found that had it. I stumbled upon it when searching around for speedometer problems. Sorry can't find the link.
