-   -   Ignition switch removal 1984 GMC High Sierra (https://67-72chevytrucks.com/vboard/showthread.php?t=58587)
hippie667 06-28-2003 11:08 PM
How hard is it to change Ignition Switch in 1984 GMC High Sierra with tilt steering? Anything special I should know about. Thanks for any help.
Prerunner1982 06-28-2003 11:45 PM
check manual if you have one. had to drop column. it wasnt all that hard though, just make sure you get it lined up right. or else run will be start and off will be run and there wont be an off..
