Second valve cover hole on drivers side what to fit.
Cannot find a rubber bung that fits that hole at the back currently taped on bung that does not fit.Can I run a breather there or even a second pcv valve.
Re: Second valve cover hole on drivers side what to fit.
They have rubber grommets at the parts store ya can get. I've been using ducktape for last 2 years n no problems
Posted via Mobile Device |
try classic industries, corvette central, 3rd gen camaro parts places etc...thats where I got mine
You can't use 2 pvc valves and you can't put a breather there cuz your pvc valve in in that same valve cover.
Your breather needs to be in the other side valve cover so the pvc sucks through the whole engine. Plug it as long as you have a breather in other valve cover |
Mine has an oil fill cap on both sides.
You can even have an oil fill cap thats also a breather as long as its not in the same valve cover as the pvc.
The pvc valve cover needs to be sealed. You can have an oil fill cap as long as its a sealed type. |
| All times are GMT -4. The time now is 08:53 AM. |
