-   -   trac bar (https://67-72chevytrucks.com/vboard/showthread.php?t=586794)
1966FLEETSIDE 06-30-2013 01:26 AM
trac bar
removed trac bar to replace bushings.im not in a very big hurry to change them.can i still drive it that way(without bar)?
Captainfab 06-30-2013 01:30 AM
Re: trac bar
NO! Do not drive your truck without the panhard bar in place. That is what keeps the rear end from moving side to side.
DURG 06-30-2013 07:23 AM
Re: trac bar
I have driven a circle track car for a lap or two with a broken panhard bar. Good lord, the damage that can be done that quickly is amazing. And costly. Hopefully during the 4 minutes it took for the Captain to reply, you didn't try it! ;) On one side your wheel and tire will be hard up against the frame or inner side of the wheel well inner or bed and the other side will be up against the outer bed. There will likely be grinding noises, tire smoke, maybe a few sparks, and a really unsure catwalking wobbly feeling.
