-   -   Vent window ???? (https://67-72chevytrucks.com/vboard/showthread.php?t=587820)
bestchevyfan 07-08-2013 02:03 PM
Vent window ????
Is the vent window in a 1987 chev truck the same as a 1980 chev truck ? Thanks, buddy
blue86c10 07-08-2013 05:40 PM
Re: Vent window ????
The window is the same size. One could have 3 screws the other could have 2 screws at the top of the door. It does matter about year it depends on the plant they was built in. I have 2 sets of vent windows that came out of a 86 and 87. The 86 has 3 screws and the 87 two holes. As long as they have the same amount of holes they should fit.
68JOHNDEERE 07-08-2013 06:05 PM
The assemblies are the same size and will interchange. Where the difference is in the glass, the 87 glass is smaller with a different seal design. While the 80 glass is bigger and seal design is different.
blue86c10 07-08-2013 09:08 PM
The glass is the same in 81-87 but if you swap out the hole assembly make sure they have the same amount of screws. I'm not sure if they will inter change.
motornut 07-09-2013 10:26 AM
2 Attachment(s)
complete swap no prob
using my 89s in my 78 no probs
later ones have locks too
bigd65 07-09-2013 10:37 AM
Mine will be WITHOUT VENT WINDOWS
