-   -   Original Stepside Truck Bed Hardware (https://67-72chevytrucks.com/vboard/showthread.php?t=590831)
drmiller1 07-31-2013 05:43 PM
What was the original finish of the hardware use to attach the tailights? Bed to fender bolts were painted body color right? These were panhead screws? Seems trivial to some I'm sure, but I like to have original style hardware whenever possible. Pics are good, details are good.
tgh117 08-01-2013 10:42 AM
Re: Original Stepside Truck Bed Hardware
If I can recall correctly the tail light bracket bolts were hex heads painted to match the body.
The bed to fender attachment was pan head Phillips screws, also painted to match the body.
Keith Seymore 08-01-2013 11:12 AM
This is correct.
drmiller - be careful when restoring the taillamp brackets and fasteners. They originally had star washers, designed to gouge the paint and provide the electrical ground for the tail lamp and turn signal. If you do "too good" a job in this area then you will lose the ground and your turn signals will not work correctly.
Or - you can add an additional ground wire, snaked from the bulb socket through the wire harness and attached to the frame. This was a suitable (and classy) fix.
K
drmiller1 08-01-2013 05:12 PM
Thanks guys,
The truck came with an assortment of stainless steel hex head and Ford body bolts in the bed area. Getting things in correct order can be a slow process. Thanks for the star washer tip Keith. They are used on the lamp to body bracket's only right? Were the panheads for the fender to bed used with washers?
tgh117 08-02-2013 03:31 PM
There is a washer on the fender bolts. But its basically the same diameter as the head of the screw. When I was taking mine all apart I was trying to decide why it was really there.
I ran the extra ground wire to mine myself. If I can find my old box of bolts from my resto, I'll take a look for you and get you a pic.
I replaced every bolt in the whole truck pretty much with stainless, so they should be somewhere in my garage.
drmiller1 08-02-2013 06:32 PM
Thanks tgh117,
I am still trying to figure out where to buy those fender screws. There are many vendors who carry them. Just looking for the best deal. That washer for the fender a flat type?
tgh117 08-07-2013 08:24 AM
yea just a flat washer. I still haven't come across the box that has those in it yet, but I will keep my eye out. seems like a I have a few too many boxes of parts left over from my rebuild/resto...
I know they have them at Mar-K for like 25 ish bucks for the kit.
Good luck with your search.
drmiller1 08-07-2013 08:57 AM
Flat washers okay. I have order some fender bolts from Classic parts of America- .60 each. I will go to the local build box store for the washers.Thanks for the info.
walkerb 08-07-2013 04:41 PM
I have 2 6' stepside and 1 8' box and none had washers on the Philip head fender to bedside bolts.
drmiller1 08-07-2013 04:59 PM
Well that mix's things up a bit. I have just placed my order for screws, maybe this will sort out before they get here:). I did notice no washers mention or shown on the website.
