Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm assuming that the coilover shocks that come in the Porterbuilt stage 2 setup for the rear end are just the sleeve type and I would like to cross reference the part number to a true coilover shock. Thanks for any help.
Posted via Mobile Device |
Re: Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm confused by your question.
As far as I know the Stage two rear kit comes with standard KYB shocks. The Porterbuilt rear coilover kits do use REAL coilovers. They are RideTech's newest coilovers. ($$$) http://www.ridetech.com/store/coil-overs/ |
Keith,Ok you've always have been there to help me out and your the reason I know anything about any suspension at all. I'm baffled what's confusing that I said.
I may understand your wording now.
Porterbuilt sells a coilover kit that uses a 4-link rear suspension. He also has a coilover kit that uses his tubular trailing arms. (I assume this is the Stage 2 Coilover kit) Both still use RideTech's coilovers,... which like you said is a "monotube" design.http://www.ridetech.com/tech/coiltech/#cutaway |
I think Fox makes these for RideTech and I've heard good things about them. They are available in 3 different versions: "Available as a fixed valve, rebound single adjustable, or triple adjustable shock." |
Ok thanks for the info, I was also wondering what the part number was to cross reference. Thank you Keith
I would just contact Porterbuilt directly.
I think I'd like to go with the triple adjustable coilover. I didn't realize there were different options available.
I will call them Monday. Thanks Keith, you always come thru for us here on the board.
