What year is my frame?
I am curious as to what year my frame is? I have done some research, and from what I can tell, based on the last digit being the year, it might be 1970? Any input would be greatly appreciated.
http://67-72chevytrucks.com/vboard/a...1&d=1375989968 |
Re: What year is my frame?
I checked last night and the frame also has 467 stamped by the frame horn up front. The frame does have the dimples for power steering from the factory. Also stamped on the side of the frame on both sides it has 3935801-467, 2-15-31. Maybe this will help.
That is not the stamp you are looking for. The format is wrong, probably a part number or other stamping. Look on the top of the frame rail between the driver upper control arm and the steering gear box. The same exact stamp will be on top of the driver frame rail under the cab. You are looking for an 8 digit stamp with the second digit being a letter.
Examples: 9S123456 9= 1969 (first digit is the year) S= Saint louis assembly 123456= assembly sequence/partial VIN (6 digits only) 7A123456 7= 1967 A= Atlanta assembly 123456= assembly sequence/partial VIN let us know what you find. ;) |
2 Attachment(s)
Here are 2 more images from my frame. I have heard that some years dont have the dimples for power steering. Not 100% sure on that.
http://67-72chevytrucks.com/vboard/a...1&d=1376071489 http://67-72chevytrucks.com/vboard/a...1&d=1376071581 |
This is the only other set of numbers on my frame anywhere.
3935801-467 2-15-31 http://67-72chevytrucks.com/vboard/a...1&d=1376072488 |
Posted via Mobile Device |
BBC Mudtruck:
I have searched til i was blue in the face on here, and no luck. Its like a partial vin or something, My cab is a 72 cab and front clip, the bed is from a different year, not sure which, but has the bed side marker lights of the newer years, I only assume my frame does not match because I cant find the numbers on my frame anywhere on the VIN number. |
Where does the rear brake line end (steel line) On the pass frame rail or in the center of crossmember just behind the axle??
Could be a GMC frame from St. Louis, 1968 to 1971 GMC Vins only had 5 digits.
And 1970 is the only year they started with 50001. 68, 69, and 71 started with 10001. So my best Guess is the frame is a 1970 GMC from St. Louis. |
| All times are GMT -4. The time now is 07:58 AM. |
