Vintage Air (Kwik Perf) LS A/C Compressor Bracket
2 Attachment(s)
Anyone need a bracket that adapts a Sanden 508, SD5, or SD7 compressor to the top of your LSx engine? I have a brand new Kwik Performance bracket (repackaged as Vintage Air p/n 141808) I am ready to pass it on. http://www.kwikperf.com/lsx_ac.html They sell for $197 but I will sell this one for $165 shipped to the lower 48. SOLD!!
Re: Vintage Air (Kwik Perf) LS A/C Compressor Bracket
does this come with the belt?? an what else will need to get this to work besides compressor
The belt is not included. If you have your A/C system, including the compressor, you shouldn't anything other than a belt.
Bracket sold through ebay.
Ya that was me. Fig I go ahead an get. If you can let me know when u ship an if a trackin #. Thanks again bucks
Posted via Mobile Device |
HA HA!! I was bummed for you, thought you missed out. It should go out in the morning, I'll pm the tracking number to you as soon as I have it. Thanks for the purchase!!
anyone know how well these do in high rpm scenarios? I plan to put a/c on my truck...but it will also be raced, so I worry about that long belt derailing at high rpms.
i dont think it should be a problem as there are some guys with superchargers an turbos with no problems. if i can find a tvs for $3-3500 i plan on finding out :)
recieved the brackets today. thanx again Bucks. just got to wait on my vintage air kit to get here now
Sweet, glad it made it safely. Enjoy!
I know this is an old post How did that Kwick Performance AC bracket work out any alignment problems? I'm having problems with mine belt squealing something terrible Thank you for your time |
I'm running it with no problems.
Are you running a truck front drive or car front drive serpentine system? Did it work right out the box or did you have to modify in some way or another? I got it to work 98%of the time for me. It was a loud squeak at all times disassembled it & reassembled it for a day & a half following directions down to the T with help from the tech line on the 2nd day we decided to start shimming the bracket between the head & bracket with 20mm washers started with one & no better added the 2nd & it immediately got quite :metal: It's all good when the motor is warmed up but at cold starts I have a small chirping sound but I quess I'll just have to live with it for now I'm frustrated already & ready to get the AC hoses crimped on & AC charged & move on to the next project on my truck. Thank you for your time. Miguel 1969 Chevy C10 LQ9 Vortec MAX /4L65e |
I'm running truck acc.
I followed their directions, if I recall correctly I used the ls1 tensioner switched out the two pulleys and bought a gates belt...no shims, except the "u" shaped one behind the pulley. |
Nature of the beast when using aftermarket A/C Compressor Bracket kits made with with either Steel Plate or Aluminum Plate, Plate Stock is not held too tight enough thickness variation standards. Once a Belt squeals from misalignment.....It's done (Glazed), Even you have it shimmed correctly now, You need a fresh Belt too know for sure. |
Gatorback belts help with a lot of noise problems from things being slightly misaligned. If you buy them on Amazon they're sometimes cheaper than the house brand belts at auto parts stores.
Thx clinbarger I'll definitely try that
And Ls1nova71 yes I know the gatorback belts well I worked at a Goodyear Automotive for just over 10 years |
