light switch
I tried a search but it isn't working for some reason..
I want to replace my light switch, i know there is a button on the top side that needs to be depressed to remove the shaft but its not releasing, is there a trick to this?? Thanks! |
Re: light switch
Pull the light switch out like the lights will be on then depress the button down and then it should come out. Hope this helps. Make sure you undo the battery first or your battery will run down. Hope this helps.
Re: light switch
Re: light switch
pull the swich all the way out and push on the button.the button wont go all the way down.keep pressure on the button and push switch in and out slighty not much.dont push all the way to parking light position.keep doing this and it will come out.button will go down when it releases.hope this helps
Re: light switch
