-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   leaf spring questions (https://67-72chevytrucks.com/vboard/showthread.php?t=593487)
Dale99 08-20-2013 11:53 AM
I have a 72 Jimmy and it has a block lift which I know is not a good thing on the front. I have a source to get some used lift leafs from a 1984, I think blazer. After doing research I see the rears are the same, but front is different(main ones I am after).
What are the differences on the front? I thought most of this strait axle gear was the same.
obijuan 08-20-2013 05:43 PM
Re: leaf spring questions
Length is different. Older springs are shorter.
argonaut 08-20-2013 07:03 PM
Also check the widths at the eyes. I think the later models are wider.
duallyjams 08-20-2013 07:59 PM
There are kits to add longer spring on the front, longer spring will give a better ride and better articulation it's a win win.
swamp rat 08-20-2013 09:00 PM
Who makes such a kit and what would i Google to find it? Thanks!
Dale99 08-20-2013 10:08 PM
Thanks for info.
And agree with swamprat. Mind referencing one please?
:edit:
I just measured the width of my 72 leafs. Its 2.5 at the ubolts. Its 3.0625 at the mounting eyes. Can someone with a newer model measure theres please.
lowrollin70gmc 08-21-2013 12:07 AM
The longer kits are to install 52" Leaf springs. DIY4X and Off Road Design are two vendors that carry different versions of new mounts to swap over. It is mainly for extra flex from using longer springs but does result in a softer ride and increased body roll.
