Simple but kind of cool mod
A buddy and mine upgraded the headlights on our Harleys to LED. I put our old reflectors on blu today. H4 bulbs fit the factory plug and will even allow me to get brighter bulbs if I want to later (like ultrastars).
I think it looks kind of cool. Lighting should definitely be brighter. http://i780.photobucket.com/albums/y...pscc1ae21a.jpg http://i780.photobucket.com/albums/y...psb2b6a177.jpg http://i780.photobucket.com/albums/y...ps58f89223.jpg I really want to get a pair of the LED trucklite bulbs (they are unreal and look awesome) but to get a pair would cost around $400.... Maybe later. I am thinking about repainting the headlamp trim but don't know if fresh flat black will make the rest of the old grill look odd. |
Re: Simple but kind of cool mod
If ya got em use em! Now if you do a relay mod (posted allover the forum) you will get even more light than thru the stock wiring.
That's cool. I didn't realize Harley headlights were the same size. I used to have a Night Train, and a Sportster before that, so from one biker to another, two thumbs up.
As for your grille, what are the plans? It has a few dents. Those can be hard to correct. I ended up finding a nice used original grille, and then shined it up and painted it as per factory specs. The headlight bucket trim can be easily painted with Rustoleum semi gloss black spray paint. Just take them off the truck, and hang them from some hooks. Don't forget to paint the screw heads black. As for the chevrolet letters on the grille, I found the best way was to spend $9 on the vinyl adhesive letters that go down inside the stamped letters Posted via Mobile Device |
Gonna repaint the black areas and clear the whole thing, then add the vinyl letters. Should look pretty cool when I'm done, and almost zero cost. |
Cool idea. Never would have guessed they would fit. |
I do have an issue with the lights anyway where sometimes when they light, one will come on really dim- if I wiggle the harness it'll brighten up to normal. Probably a ground. When I tried my hi/lo beam switch Saturday night (on a very dark side road), I hit the hi-beams and the lights went OUT. That got my attention. I hit it again and the lo beams came back on. Then the next time the hi's came on. I kept going back and forth and they started both working properly. |
That's a real nice touch. A cool way to get a couple little HD emblems on your truck.
Traditionally,the FL Harleys use 7" lights and FX and XL use 5". There are exceptions in the latest models. 7" is what vehicles with single headlights use and 5" is for dual headlights. EDIT: I'm sure you have a bad ground |
not to hijack my own thread, but since you brought it up.... Here's the first one, the 96 1200. A very cool little bike but just a bar-hopper, it was lousy for long rides. http://i780.photobucket.com/albums/y...psf171811b.jpg My need for speed phase (I used to do 160-170 mph once a week just because I could): http://i780.photobucket.com/albums/y...psaf9b0fc2.jpg http://i780.photobucket.com/albums/y...ps73199fed.jpg http://i780.photobucket.com/albums/y...ps96c33e87.jpg and finally my current ride- 05 FLHTCI, currently with a fresh 106" 120 HP, 122 FT-LB mill with some suspension work done to make the big girl handle better (so much for slowing down). This one's got 80K on the clock and been coast to coast 3 times. Lots of iron butt stuff.... (this is a UT pic BTW)- the bike is a bit dirty as it was a few thousand miles into the trip already. A few things on it have been changed now.... http://i780.photobucket.com/albums/y..._1744Large.jpg back to the truck- I need to see if I can find someone that can straighten out the grille- with all the complaints I have heard about the repro stuff, I am hesitant to get one. The NOS stuff is crazy expensive. I am kinda looking for a clean used one but haven't found it yet. I'll spray the headlight bucket trim (I don't see repro ones black - did they just do them for 70?). I guess as far as painting the grill I need really good masking to keep the lines tight. It'd be nice to take off the anodizing and then polish and paint it. I've seen the Chevrolet decals and figured that'd be the easiest way to go.... I did place an order with LMC last night including new fasteners for the trim and a new retainer ring (one of mine is missing two of the three tabs). So...I'd like to find someone that can maybe straighten this one locally first. Plan "b" is to replace it. |
I actually bought a little dry-erase board and started listing jobs so I can keep focused. |
For good lines when painting I recommend Frog Tape. I haven't seen repro black headlight buckets either, so mine are getting wire wheeled and repainted. If you find somebody who can do hammer and dolly work, they can probably straighten that grill out. My truck came with an extra grill, that is better than the one on it but it still had 3 large dents in it. I bought a cheapo hammer and dolly set at Harbor Freight, and watched a bunch of YouTube videos of how to do the work. I got it pretty straight now. Better than my installed grille, and not bad for a driver. |
sounds like a bad hi beam switch on the floor....internal contacts corroded
If I have to get another grill I might try a DIY on this one. As beat up as it is already, what's to lose, right? |
Lots of TLC needed on these old trucks. Gotta keep remembering how old it is and this is why I got it. To tinker. Thanks. |
Thats what I figured. PO threw in an extra grill with the truck, so I decided to see what I could do with it. Repaired and repainted the inner grille and it looks like new (except all black), then started on the outer. I sprayed some clear on it last night to see how it will look, and I like it. But the clear revealed some areas that didn't show up without, so I will probably strip it again and work the finish some more. |
Cool mod! That's a good looking bike, too! Since this is a self hijacked thread already, I'm gonna post a pic of my baby too! :)
https://photos-b-dfw.xx.fbcdn.net/hp...81607331_n.jpg https://fbcdn-photos-e-a.akamaihd.ne...25664704_n.jpg Posted via Mobile Device |
As for the headlight trim buckets on a 69/70, black is factory correct. The repro parts are wrong. They are chrome. I'm guessing they must also fit 71/72, that are supposed to be chrome, so they saved a buck and made one part number for 4 years. At the end of the day, it is wrong for a 69/70, and I think looks way better in black Posted via Mobile Device |
In 67/68 Chevy used steel headlight doors painted white or polished aluminum on the fancier trucks. In 69/70 they used steel painted black. Then,in 71/72 they used aluminum polished to match the grille. Only the 71/72s are reproduced and fit 69/70s. You have to paint/powdercoat those or use good used ones.
these 55/100 Hella bulbs make nighttime driving AWESOME! just don't forget to hit the dimmer with traffic! :D
