-   -   Roaring inside cab with A/C on (https://67-72chevytrucks.com/vboard/showthread.php?t=594902)
Jake Wade 08-31-2013 11:06 AM
85 GMC 1/2 ton 2WD with a 305. This truck has the R4 style compressor.
What could cause a roar inside the cab when the A/C is on that fluctuates with RPM. Unfortunately it is at its worse at cruise speed, 1800-2100 RPM.
Just installed a brand new Four seasons compressor, dryer, and orfice.
It has the proper oil and the charge is correct.
BTW, I have new motor mounts and all factory brackets installed correct.
Proper tension on new belts also.
Not noticeable standing outside looking under hood.
GM-power 08-31-2013 10:36 PM
Re: Roaring inside cab with A/C on
Does it make the noise on the vent or heater settings?
Jake Wade 09-01-2013 06:32 AM
I have not tried that. It only does it when the compressor clutch is engaged.
I am guessing I have a bad compressor. It cools well though.
bigd65 09-01-2013 09:06 AM
If you converted it to R134, it's because the CONDENSOR does not have large enough hole to allow for the thicker R134.... Same problem with mine and same problem I had with my 85....
Jake Wade 09-01-2013 09:39 AM
AHA! This could be it! If I bought a new direct fit condenser for my truck, Would it be compatible with R134?
bigd65 09-02-2013 10:19 AM
I would think you should be able to. Just make sure it's 134 compatable. The other is not even available anymore or at least cost effective, I'm sure someone will make one... I have to do the very same when I get my truck back from paint
