-   Blazer and Suburban Stuff (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=199)
-   -   GA Parting 72 Blazer Frame (https://67-72chevytrucks.com/vboard/showthread.php?t=596250)
uncle 09-10-2013 08:46 PM
Frame is rusty in rear. Most body mounts good. Has engine and t-case x-mem. I'm not much on 4wd trucks so I will price few things and y'all can ask about anything else. Extra front/rear are 308. Got dark so will get ratio on rolling front/rear. No brakes on roller either. Power steering pump 55 plus ship,power steering box 60 plus ship, speedo cable 30 shipped, auto frame linkage piece only 20 shipped. Wheel are not blazer. Respond in post.
uncle 09-10-2013 08:48 PM
Re: Parting 72 Blazer Frame
uncle 09-10-2013 08:49 PM
uncle 09-10-2013 08:50 PM
uncle 09-11-2013 04:54 PM
Didn't believe guy when he told me but checked front/rear today on roller and gears are 5:37. Good for swamper or rock crawler I guess.
1972K20 09-11-2013 11:33 PM
Look at the part circled in the pic. Does that support the transfer case and will it fit on a K20? Thanks
DeadheadNM 09-12-2013 12:09 AM
Good luck with the sales - the 4wd specific exhaust hanger on this frame would find good use on a build for someone adding dual exhaust - there are matching frame holes on the opposite side. Imparts a more stock (and symmetric) appearance to a dual exhaust setup IMO. I went this route on my K20 build.
DeadheadNM 09-12-2013 12:15 AM
How much shipped to 87110 for the:
1) frame bracket w bolt/nut for the pwr steering lines
2) the non-pressure metal pwr steering line
3) blue front hub dials if present, available, and in good shape
Wants not needs. Thanks! Pete
uncle 09-12-2013 08:05 AM
1972K20 I can't answer that. Deadheadnm 5 for ps part shipped not going to take line of pump and only has one side on hub dial and its shot.
DeadheadNM 09-12-2013 08:58 AM
That NP205 support circled above will work for a K20 IMO - if I needed one I would buy it for my K20
I'll take that frame bracket w bolt and nut that secures the pwr steer lines. PM payment details when poss. Thanks, Pete
uncle 09-12-2013 10:43 AM
Deadheadnm pm sent
Jdubs71 09-12-2013 11:22 PM
Price on the two supports attached to the transfer case x member and the circled red part if 1972k20 passes
DeadheadNM 09-12-2013 11:42 PM
FYI: The tranny x-member on this frame can be used to install an OEM NP205 skid plate - just need to cut the rivets off holding the bracket attachments for the upper frame and you have the correct piece...good luck with the sales
cst204x4 09-13-2013 12:05 AM
Interested in 4x4 speedo cable can you post pics
blazerboy72 09-13-2013 09:26 AM
Is the frame repairable or too rusted?
uncle 09-13-2013 08:18 PM
Jdubs71 35 shipped.cst204x4 after 2nd look cable has bad place on it. (Pic).blazerboy72 here's some pics.
uncle 09-13-2013 08:23 PM
Cable
uncle 09-13-2013 08:25 PM
Frame
uncle 09-13-2013 08:27 PM
uncle 09-13-2013 08:29 PM
4
uncle 09-13-2013 08:31 PM
Pic
1972K20 09-13-2013 09:06 PM
uncle, can you get me a price on the transfer case support bracket shipped to 36830. Thanks
uncle 09-13-2013 09:28 PM
30 shipped
