-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Body lift (https://67-72chevytrucks.com/vboard/showthread.php?t=596291)
unclefreddy 09-11-2013 01:36 AM
Body lift
Does any one have pictures of a 67-72 suburban with a body lift ? I picked up a 6BT mated to a Allison 3060 6 speed transmission and might have to do a body lift to get the trans mission in. Thanks
vectorit 09-11-2013 08:27 AM
Re: Body lift
I wouldn't do any kind of body lift.
The guys that have done the kind of swap you are planning here on the forum, they all appear to position the lump as to not get into the way of the body as much as possible. Then they cut, and form the body work where it is tight.
Have you checked out the diesel swap section?
"Mosesburb" is one that comes to mind, where he put the 6BT in and points out a lot of his trouble spots while installing and maintaining the system.
unclefreddy 09-11-2013 01:03 PM
Re: Body lift
I know that the 6BT will fit not so sure on the Allison 3060. I will have to do a body lift and or cut the transmission tunnel out to accommodate this big tranny. Should be interesting !
unclefreddy 09-11-2013 01:10 PM
Re: Body lift
Allison 3060. Length 28.16 inches, depth 11.13 inches, dry weight 535 lbs.
unclefreddy 09-14-2013 05:45 PM
Re: Body lift
I'm liking my transmission tunnel, it's huge. Might be easier than I thought getting that Allison 3060 in there !
unclefreddy 09-14-2013 06:11 PM
Re: Body lift
I can't find the diesel swap section ? Throw me a link if you have time :) Thanks
