1972 c10 voltage regulator installation
Wondering if the voltage regulator on my 72'c10 should be rubber mounted.
thanks. |
Re: 1972 c10 voltage regulator installation
Yes. The rubber mounts are called Wellnuts. I believe they are 10-32 treads.
If you can't find some let me know. I have a few left. |
nevermind, double post
Thanks wrenchdender, I will try to find some.
Anyone have a pic to show how these rubber mounts are mounted to the regulator? Thanks
Like Wrenchbender said, the "rubber mounts" are Wellnuts. You stick the Wellnuts into the holes in the radiator support. Place the regulator in position, and insert the mounting screws through the holes in the regulator base, and thread them into the Wellnuts. As the screws are tightened, they cause the ends of the Wellnuts to expand and that keeps them from pulling back through the holes in the radiator support. |
Thanks I got it mounted tonight. Worked great thanks
